A few problems with 385 stroker... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2010, 03:20 PM
Dan
I just put in a newly machined 385 stroker with all new internals, started it up and on the passanger side, sounds like some lifter noise, i tried to adjust the rockers multiple time without any change.. also at about 2100-3000rpm there is a noticable shake from the drivetrain... any suggestions??
Old 08-05-2010, 03:29 PM
Greg T's Avatar
www.krusinklassics.net
Got the proper flexplate/flywheel for your rotating assembly?
Old 08-05-2010, 03:35 PM
327NUT's Avatar
What Greg T said....also is this one of the "supposedly balanced assembly's" or did you personally have it balanced? As far as the lifters are concerned, did you use a good oil additive when breaking in the cam, might have a lobe or 2 going south if not.....I truly hope you don't though.
Old 08-05-2010, 03:47 PM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
Did you have the rotating assembly balanced? Could be an exhaust leak from the headers. After a freshly rebuilt engine warms up and cools down a few times the header bolts can come a little loose. Check them at both ends.
Old 08-05-2010, 04:23 PM
Dan
I had a guy that does machining for a living put it together, so i honestly cant say I did it myself. He told me he put straight 30 weight oil in it to break in the cam (lunati voodoo 60104), i just got the motor running sunday and changed the oil last night and put in 7 quarts of VR-1 racing oil. started the car, same thing... i hope i dont have any bad lobes on the cam either, there shouldnt be its brand new, but that doesnt mean everything. the flywheel, i dont believe is balanced, i could be wrong though..
Old 08-05-2010, 06:28 PM
406 bug's Avatar
9.82 @ 139mph
rotating asmbly. clearance????
Old 08-05-2010, 08:09 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
that could be your problem if he didnt use an oil with zddp or a zinc additive. but i wouldnt jump to something as horrific as that. check that the rocker arm nut isnt bad also. i had to go bad on mine and every couple miles had to tighten in back up. then i just replaced all of them and no problems since
Old 08-05-2010, 08:30 PM
hemi joe's Avatar
loves ex cop cars
who the heck makes a 385,come on guys what are you talking about,is this a foriegn car????//////
Old 08-05-2010, 08:45 PM
techinspector1's Avatar
Wiki Edits: 326
4.040" x 3.750" = 384.56 cubic inches, rounded off to 385.
Old 08-05-2010, 09:03 PM
Wiki Edits: 326
So, there were no further instructions for the cam break-in?
If he used the springs recommended by Lunati for this 60104 cam (#73943), then here's how it plays out. The installed on-seat pressure at 1.750" is 108 lbs. Between the intake and exhaust lobes, the exhaust lobe has the most lift at 0.525". The spring pressure is 462 lbs per inch. Multiplying 462 times .525 tells us that there will be an additional 242 lbs of pressure on the tappet at full lift. This is in addition to the 108 lbs of seat pressure, so the total pressure on the tappet at full lift is 350 lbs. This is unacceptable on a flat tappet camshaft and is the range of pressure you would expect to see in a hydraulic roller tappet camshaft installation. In my opinion, not only is it unacceptable after the camshaft is broken in on lesser springs, then changed to the stronger springs, but to try to break in the cam with these springs in place is an exercise in stupidity. I'm very surprised that Lunati would spec such a spring for a flat tappet camshaft.
Just my opinion you understand, but I think your engine builder should be tied to a pole and caned for not explaining all this to you.
Here's a tutorial I wrote for the Crankshaft Coalition Wiki. Maybe you'll gain some insight from it....
http://www.crankshaftcoalition.com/w...ricks#Cleaning
Old 08-05-2010, 09:22 PM
hemi joe's Avatar
loves ex cop cars
it's still a 350 sbc bored .040 over .what year was it was inducted to become a 355,383,385,whats next a 625.they are all 350 motors,stroked or not stroked.
Old 08-05-2010, 09:30 PM
Wiki Edits: 326
Having a bad day Joe?
Old 08-05-2010, 09:34 PM
hemi joe's Avatar
loves ex cop cars
yes i'am,i can't seem to find anyone to come up with a set of heads for my motor.sorry for the stupid remark,i just am fustraited.
Old 08-05-2010, 09:41 PM
Wiki Edits: 326
What is it you're looking for? Maybe the rest of us can help.
Old 08-05-2010, 10:28 PM
hemi joe's Avatar
loves ex cop cars
i don't want to jump 87montes post,i will start my own post.sorry 87monte.
383 stroker clearence problems blazin_kustums Engine 6 02-05-2008 08:01 PM
mini starter problems gilbert773 Engine 1 10-30-2007 02:37 PM
Stroker! thefloyd1973 Engine 4 04-16-2007 12:34 PM
383 Stroker Question thebellman Engine 3 02-01-2007 03:56 PM
can't start a 383 stroker inquiring_mind2 Engine 19 12-31-2006 10:51 AM
