Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Few questions on a 350 sbc build up...
Old 07-15-2012, 08:24 AM
Uniryan2008 Uniryan2008 is offline
Yes that is the cam I have, and that street dominator is the dual plane z28 style, I knew gears were a givin if I want it to have any jump at a stand still, so that will be a part of this build, it has the stock rear end which I can't find any gearsets for, i was thinking an early 90's reared should be a lot better seems how I can hop it up a bit easier, any suggestions???. What about a throttle spacer should I put it on or leave it off??, one of my wrenchin buddies says some offer brutal low end add, and I was told also they where for tuning not all that?? All I know is you can slap together a bunch of ****** ****,but if ain't tuned right it ain't gonna be worth a ****, I've built a lot of power jus gettin it all dialed in and tuned perfect
