Few questions on cam bolt locking plate plus retainer plate. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2009, 04:08 PM
Hello guys I have a few questions about a 350 chevy oem roller cam setup. I have the later model chevy 350 1 piece rear main seal roller block and have a oem roller comp cam to put into it. I noticed the bolt pattern is closer together then the older style and was wondering will I be ok without using a cam bolt locking plate? I can't even find one for a oem roller bolt style and I don't think they make one or I would use one for extra insurance. Also if I just use locktite on my cam bolts and torque them down to 20 foot pounds should they stay in good? I have heard different stories on if you don't use them your cam bolts will come out over time and some say they won't.I know a lot of people use the cam bolt locking plates on the older style cams. Also do I use locktite on the little bolts that hold my camshaft retainer plate that keeps the cam from walking forward? Thanks for info.
Eric
Old 05-04-2009, 04:19 PM
Rogers Performance's Avatar
Listen some guy a hundred years ago had a cam bolt come out so know every one has to have a cam lock plate. Clean the bolts and threads out put some red lock tight on and TQ. to proper number you will be good to go.
cam lock plate Blob Engine 2 05-07-2004 11:30 AM
cam regrind questions newchevyman Engine 3 04-22-2004 02:11 PM
cam questions jboxcar818 Engine 4 02-26-2004 12:46 AM
cam scrapes rod bolt gaino Engine 1 03-28-2003 11:34 AM
converting GM 10 bolt to rear disc brakes, have questions HotRodF100 Suspension - Brakes - Steering 7 09-18-2002 11:22 AM
