Few questions on paint for my blazer - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2004, 05:51 PM
Blazin88's Avatar
New Member
I want my blazer to look like an old hot rod. I want to do a flat black bellow the body line and do a flat red above the body line. Like a red primer. But I plan to leave it like that. How can I get a flat red look? Could I get red primer sealer and some flat black and then clear over it?
Old 07-13-2004, 06:11 PM
Blazin88's Avatar
New Member
Here is a quick photoshop. Just to give you an idea.
Old 07-13-2004, 06:19 PM
Blazin88's Avatar
New Member
Oh and how much do you think it would cost for black and red primer sealer?
Old 07-13-2004, 08:05 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
you have the right idea on how to do it. remember to add some crap or other i can't think of the name of right now to the clear, so it won't be so glossy. flattener? call around your area for prices, some primer/sealers go for as high as a couple hundred dollars a gallon.....
Old 07-13-2004, 11:20 PM
Randy Ferguson's Avatar
Ferguson Coachbuilding
Last journal entry: '41 Chevy sedan
Paint it the desired base colors and shoot a couple coats of PPG DCU2060 "flexed and flat" clear. Based on the % of gloss you want, you can mix this with DCU2021 or DCU2002 clears (and possibly others) to get just the look you're after. Do a test panel and allow it to dry to see what the results will be.
Randy
Randy Ferguson
Metalshaping & Kustom Paint
www.metalmeet.com
Old 07-14-2004, 01:08 AM
Blazin88's Avatar
New Member
Here is the exact way I want to do it. I forgot to add I wanted a white pinestpripe above the body line. So to get a flat look I can get any black base coat or do I need a satin or sueade black base coat?
