All of the clears I've used get yellow/brown over time, even the high-heat engine clear coats. I finally got frustrated and used aluminum-colored paint. It looked a little "metallic" at first, but with heat it calmed down.
One of the secrets is to use a phosphate etcher that is designed to prep aluminum for paint. Otherwise the first time you try to blast it clean with a pressure washer it will probably just pull the paint right off Do they make a clear powdercoat? |
| Radiator flush - KOOL CLEAN, CLR , etc which best to use? | dbuff | Engine | 2 | 07-13-2004 10:37 PM |
| 2 Ques - KOOL CLEAN and pls help locate up rad hose | dbuff | Engine | 0 | 07-12-2004 01:20 PM |
| More Por 15 questions ? | FiefSS | Body - Exterior | 2 | 09-25-2003 10:10 PM |
| Some quick fiberglass questions... | 94max | Interior | 5 | 06-30-2003 04:21 AM |
| two quick questions | Blag | Engine | 2 | 02-05-2003 03:30 AM |
