FI to carb swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2012, 06:03 PM
FI to carb swap
hi my name is jeremy and i have a 86 monte carlo base model it had a 4.3 FI and a 200c trans im putting in a 406 that's carb and it's gonna have mechanical fuil pump i want to get rid of alot of the wireing harness but i am using the old altanater and im gonna put the a/c back in it.. in the future..what do yall think would be the easyst way to do it ???
Old 02-01-2012, 09:11 PM
gonzo08383's Avatar
Last journal entry: brakes
buy a painless wiring harness with fuse block. should run about 400. will be a cleaner install and you wont have to worry about leaving a clipped wire still "hot". just my opinion. if you dont have the cash then rip all the wires out 1 by 1 as you dont need 'em. alternator needs a sensing wire, charge wire and a ground. distributor needs a keyed hot(12v) tach and a good ground. starter needs the start wire and the big 4ga(sometimes bigger) red wire from your battery+. pretty much all you need to drive. dont rip out any of the relays or associated wires, they are probably important. can i suggest a vintage air system for your a/c? i installed one in my camaro in a weekend. so easy and simple. 1200 bucks well spent.
Old 02-02-2012, 05:29 AM
Banned
I would just buy yourself the wire you need and make your own harness, its much easier to tuck the wires that way and its really not that hard once you get started. I had to install an electric fan, electric fuel pump, and swap the ignition from duraspark to TFI last night and the wiring for all of it took less than an hour. Save your relays even if you don't use them, there's always something down the road that needs a relay.
LS1 Carb Swap and Cam Swap. Hacksaw Engine 27 12-15-2013 08:40 PM
94 350 tbi to carb swap. jerryvarnell Engine 7 11-19-2011 11:27 AM
carb swap jrm123180 Engine 3 08-19-2009 09:54 PM
TBI to carb swap eatonde Engine 20 09-09-2008 11:01 AM
carb swap 1970CDV Engine 2 04-22-2002 08:44 PM
