-   -   fiber glass (http://www.hotrodders.com/forum/fiber-glass-73171.html)
FEDDO 10-31-2005 01:58 PM
fiber glass
I need some flat fiberglass panels. aprox 2'x5'x3/16 thick. where would a person start looking? finished one side, would be good. thanks, jim.
OneMoreTime 10-31-2005 02:10 PM
Make those
Those are called flats in the fiberglass trade..make a table with formica top ..wax it up good and then layup your panels as needed..I have looked for that sort of thing and no one I know makes panels like that..Just keep adding material until you get the thickness that you need.. :sweat:
OMT
FEDDO 10-31-2005 05:39 PM
fiber glass
Thanks for the reply. some one makes panels. I know the mil has the material.
hotroddr 10-31-2005 05:47 PM
panels
I read in another forum that they are available at Home Depot- something used for showers. Bill :)
mrcleanr6 10-31-2005 06:19 PM
its called pultrusion. thats actually the name of the process of making the stuff but thats usually what its refered to. you would need to goto a plastics supply house and buy it or have them order it. here is one online, they have it available in 1/4".
http://www.rparts.com/Catalog/Box_Building/frp/frp.asp
FEDDO 10-31-2005 06:40 PM
f glass
Thanks for the replys. the on line store didn't have the size I need. I will continue to look.jim.
mrcleanr6 10-31-2005 06:50 PM
ahhh!! here you go. just pulled out my mcmaster carr catalog and they have it. you can get sheets in 3' x 5' x 3/16" and its reasonable too. goto www.mcmaster.com. the part # is 8549k85. they do have others too. here are a couple more #'s 8537k15 , 8494k11.
FEDDO 11-01-2005 04:26 AM
fiber glass
Thanks for all the replys. I knew it was out there. Mr clean, that was spot on. .thanks, jim.
