Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - fiber glass kick panel
Old 02-28-2012, 09:37 AM
ogre's Avatar
ogre ogre is offline
the 'Duracell Project'
fiberglassforums.com has a whole sub-forum dedicated to building kicks, that's where i'd start.
i'd start from scratch if they mount easy. if the mount is complicated try to build off a junkyard set.
if you build off the original kicks you will need to use the kick as a base for mounting purposes.
am i making sense here?
