fiber glass kick panel - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2012, 07:57 PM
I wont to make some new kick panels from my 81 Datsun 4x4 to put some bigger speakers in. Since it may take me a few trys i don't wont to sacrifice my originals. there are a few contours i have to contend with. So this is my plan. I was going to cover my kick panel with saran warp, Then lay the colt over it with resin on it and let it dry. Then use it to build off of. will this work?
Old 02-25-2012, 08:13 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
In a word, YES.
Old 02-25-2012, 08:26 PM
ogre's Avatar
the 'Duracell Project'
saran wrap will melt. use aluminum foil.
go to fiberglassforums.com, i learned to do this there.
Old 02-27-2012, 05:49 PM
OK should i just lay one layer of mat down on the original panel, and let it dry then build up, are just build from the beginning?
Old 02-28-2012, 09:37 AM
ogre's Avatar
fiberglassforums.com has a whole sub-forum dedicated to building kicks, that's where i'd start.
i'd start from scratch if they mount easy. if the mount is complicated try to build off a junkyard set.
if you build off the original kicks you will need to use the kick as a base for mounting purposes.
am i making sense here?
Old 03-07-2012, 07:48 AM
Man that is a beautiful job there Ogre!
Old 03-08-2012, 03:44 AM
I've used a t-shirt before. Mount the "pods" for the speakers, then stretch the t-shirt over the whole kickpanel tight. Coat t-shirt with resin. I made a set for my f150, turned out great.
Old 03-14-2012, 11:23 PM
i made a console for my impala
Old 03-15-2012, 01:49 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Nice work. You can also use fleece as a base for the resin. Anything stretchy and absorbent.
Old 03-15-2012, 08:07 AM
You are one slick dude, looks great.
Old 03-15-2012, 01:40 PM
ogre's Avatar
thank you
Old 07-16-2012, 07:33 AM
ajbcc2's Avatar
Last journal entry: frankenstude too
i never had a problem with siran wrap melting just maybe tearing. I use duct tape alot..just try to keep resin from the glue side..so good closed seams is a key..
1st attempt at fiber glass 68Birdman2 Interior 9 01-31-2010 12:18 PM
painting fiber glass? little chevy2 Body - Exterior 2 10-12-2006 08:13 PM
Fiber glass or steel CrazyRoyExhaustfreak Hotrodders' Lounge 8 04-19-2006 08:40 AM
fiber glass FEDDO Body - Exterior 7 11-01-2005 04:26 AM
How to on Fiber Glass Parts SnapCase Body - Exterior 10 05-23-2003 04:02 PM
