Vince |
kleenstrip aircraft stripper says right on the can " do not use on aircraft "
Brian |
The reason it says not for aircrafts is because it will eat aluminum...and fiberglass...and plastic ....it'll even soften up two inch thick bondo to where it'll pop right off with a stiff putty knife... its really simple to use but does take a little common sence on the users part, so its not for everybody. we had a 32 that a customer had acid dipped and it looked great but I wouldnt use acid dip on a vette either. Well there a few out there that should try it... I had a spray gun I rode hard and put away wet one night and forgot about.when I went to use it again it was set up tighter than a rats as,so I used some stripper to clean it ....Big mistake ,eat the finish right off it and the gun never worked right again.... |
epoxy is the best to seal glass. 2k urethane primer is useless except in collision work. it shrinks and swells . i use nothing but epoxy on corvettes.
I spoke to you several years ago about my paint nightmare on my 71, I stripped 90% of the paint off and where the old laquer was left it reacted with urethane sealer and paint. the strong solvents caused the old laquer to cause solvent pop problems so it needs to be taken all the way down again. this is the reason it has sat for several years. anyway whenever i get back to it should i just use epoxy as my high build for blocking |
at least use 2 coats of spi epoxy . i do one heavy double coat at a time. block and repeat until i'm satisfied then one reduced coat and start painting. many use polyester primer also. your choice. but urethane primer is for collision work.
the only thing i use on glass is polyester,but i have never tried SPI epoxys.
i re-did a family memebers 63 vette many years ago and didn't really have any guidance made it look nice. mistake i used Dupont Euro 2k on the job and a lot of it blocking and priming. 6 months later it shrunk so bad you could see when it got warm the actual weave in the glass. total nightmare,ending stripping all back off and re-doing all body work and using polyester primer this go around,sanded like a ***** but worked,after that any thing glass i touch has polyester on it. for some reason i thought Epoxys were non-sanding,and mainly a corrosion preventive step. what makes SPI so different? thanks for any input,and glad i could share my horror story,Travis
Vince |
thanks,i have just ordered other products from SPI.guess ill have to order a batch of the epoxy next go around |
funny thing is I was using SPI for a couple years because it sanded easier I never even tried to do a full sanding I just 80 grit sanded and applied the 2k ..Thats what I always did but when I joined HR they said it could be built up and sanded like a 2k ,When I tried it I couldnt believe it.Thats why I post about it so much .....Its that impressive.....One of very few GREAT products I've found,and its realitively inexpensive too....I'll never switch.... |
| Firestone and my experience with Customer Service | Countilaw | Off-Topic | 12 | 08-25-2010 06:22 AM |
| The Experience Hendrix | dinger | Off-Topic | 11 | 03-15-2010 12:54 AM |
| Anyone have experience with Speedway's Tru-Ram headers? | Harley Monster | Engine | 11 | 03-09-2010 10:56 PM |
| Getting Rodding Experience without having a car | kgard | Hotrodding Basics | 10 | 09-02-2009 07:19 AM |
| My first compressor piping/painting experience - lessons learned and questions! | mpaq | Body - Exterior | 17 | 07-27-2007 01:46 PM |
