Fiberglas or urethane - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2004, 04:13 PM
I have an option to get some (basically aerodynamic stuff, so close to the ground) stuff in either fiberlas or urethane.
Is there any drawback to using glas. The urethane stuff is about twice the price.
Are road rocks, etc. going to crack or whack one worse than the other? I'm thing about spraying Scufgard on the underside of whatever.
Thanks,
Seth
Old 03-12-2004, 04:16 PM
poncho62's Avatar
Wiki Edits: 5
If you are looking to make an air dam close to the ground, I would go with rubber. Fibreglas will shatter and I don't think urethane would be much better.
Old 03-12-2004, 08:16 PM
I'm looking at kits that run the length of both sides, plus a roll pan. The bottom edge would be 6-7" off the ground.
