fiberglass
can someone give a guide to make a fiberglass sub box?
Like vince says works
Here is another suggestion, if you leave the particle board in the laminate it gets really stiff and sounds better. Don't tape it off if you want it to become part of your finished box. Mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
here's a few links
WOW puttster, Those are some really in depth informative threads you posted.
If someone can't build a professional looking sub box in anything with all of that I would be surprised. Good stuff ! I got to read ALL of it when I gets the chance. later, Mikey
How to fiberglass tutorial
here's maybe the best tutorial out there.
http://web.njit.edu/~cas1383/proj/main/ My first project is a console for my old car. I have learned: You need to figure out a system for mixing resin. containers & measurements. Do not just grab a pan and squirt in the hardner each time. Once the resin starts to jell do not try to spread it. It is not like a hunk of jelly, it won't spread out at all. The cloth is easier to work with than the mat. Use the mat later, as reinforcement. If the resin gets on you do not use the laquer thinner to rinse it off. I do not know what that stuff is supposed to be used for but if it touches you you will burn! |
| Recent Interior posts with photos |
| Yet another question about bonding fiberglass to metal | Psionic | Body - Exterior | 37 | 01-17-2010 08:03 AM |
| Gap problems fender to door when front fascia installed | Ripped | Body - Exterior | 25 | 03-19-2006 07:15 PM |
| Fiberglass Advice | Classix_Lover | Body - Exterior | 9 | 07-20-2005 11:31 AM |
| fiberglass to fiberglass scoop | bluebu | Body - Exterior | 62 | 06-23-2005 05:15 PM |
| Fiberglass help for novice | tyman00 | Body - Exterior | 1 | 10-20-2004 12:36 AM |
