This may help some of you beginners out there reading this thread !
Jester
After using the laminating resin (Evercoat # 100560, 100561) Use one of these final coats Depending on the perticulars of the project!
Waxing resins: Also called Finnish coat.
Marine and Fiberglass Resin (Evercoat 100552, 100553, 100554, 100517, 100518, 100519, 105498, 105499, 105501 and 105502) are non air-inhibited or waxed resins. They are for the final coat. This resin cures with a hard, non-tacky surface. When the catalyzed resin is applied as a final coat to the laminate coats of resin, the wax rises to the top, sealing off the air and allows the resin to cure to a hard finish, which can then be sanded, painted or gel-coated.
NOTE: Cannot be used with aluminum, redwood and/or close-grained woods like oak or cedar. For redwood, cedar, oak or other oily or close grained woods, Evercoat Everfix Epoxy (100642, 100643) will provide the best adhesion.
Do not use with Styrofoam.
