Originally Posted by painted jester
Forgot to add this: If using Epoxy resin it also has a downside in that an amine blush, which feels "waxy" on the cured epoxy, the waxy blush must be washed away with warm water before successive layers can be laminated! if you don't do this your layers will eventually peal like a loaf of sliced bread!!
Jester
Sorry Jester.. But the wax don't just wash off.. If your using the resin with the wax.. The right way to add anymore layers, Is to sand it with 36 grit paper, Then wipe it with acetone, It will become tacky again, Then add your layers..That's the right way to work with resin with wax..
