Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fiberglass & bondo for skim coating?
  #35 (permalink)
Old 02-12-2013, 05:49 PM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
Originally Posted by painted jester View Post
Well your saying basically if its done wrong it wont bond!!!! thats different then the absolute statement "you cant" We all agree on that I see welded patches bubling up rust under paint shortly after being repaired by some shops!!! It was lousy prep and an untrained person. It was the right way but done wrong!
I weld patches in holes and rusted areas!! Sure its right but not the only way! Hell they are gluing patch panels on now! I would have thought that crazy years ago! And Ive seen riveted patches done right that still look good 30 years later! Its ability that decides whats good or not, not the process to meet the same end desired! Fiberglass layed on fiberglass will pop off too if the right prepping isn't adhered to!
Jester
I agree.. I'm saying fiberglass layed on metal will not bond for very long.. Done right or wrong..
I'm also saying fiberglass parts can be boned to metal with the RIGHT bonding stuff,, Not resin..
I would rather see someone pop rivet,or bond a patch on then use fiberglass on metal anyday... Will hold up longer...
