Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fiberglass & bondo for skim coating?
  #37 (permalink)
Old 02-12-2013, 09:13 PM
M5StudeGuy M5StudeGuy is offline
Originally Posted by NEW INTERIORS View Post
I agree.. I'm saying fiberglass layed on metal will not bond for very long.. Done right or wrong..
I'm also saying fiberglass parts can be boned to metal with the RIGHT bonding stuff,, Not resin..
I would rather see someone pop rivet,or bond a patch on then use fiberglass on metal anyday... Will hold up longer...
OK.. I'm reading this thread and you folks are getting me worried...
I applied fiberglass to the roof of my truck. I was told it was fine..
SO let me detail what I did and give me your thoughts.
I stretched the cab of the truck and it wasn't quite level,.. so we added fiberglass to fill the low spot. We did this:
Sanded the metal with 40 grit paper.
Put on epoxy primer.. sanded again with 80 grit.
Then we put on a layer of resin, a layer of fiberglass mat, resin, mat and then resin (all at once). Stuff is hard as a rock.
Then we put fiberglass out of a can on top of that to help with the small low spots (some on top of the fiberglass/resin mix, and some on bare metal), and finally bondo to make final adjustment to make it perfectly smooth.
We sanded with 40 grit between each application.
SO please tell me I'm not going to have any problems...
