Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fiberglass & bondo for skim coating?
  #38 (permalink)
Old 02-12-2013, 08:15 PM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
Originally Posted by painted jester View Post
I see we agree LOL
I never stated you could bond fiberglass to metal with resins in any of my posts! I was only trying to make clear the different resins and materials! for young readers I do bond glass or carbon fiber to metal but its a different process then just brushing on resin and sticking them on! and like Brian I have stiffened up or made complete floors out of fiberglass or Kevlar and have filled small holes in floors after epoxying and then laying out cloth and resin! and never had a lamination let loose Except when I was young and learning!!
I like Evercoat Ive tried others but keep coming back to Evercoat!
Large overhead areas are hard by myself and messy I use rolled material (like a paper towel roll) and when the resin is tacky enough to hold the weight I roll out the material a few inches at a time and with a roller I press it down and smooth out the wrinkles The corners are the hardest I usually have to re wet them! For very large areas I use helpers! I also buy thinner mat so its not as heavy! The vertical large areas are easy with the right laminating resin! The trick is in the mix, and when you apply the mat! every day its different so I mix test pots to see what mix works best mix too hot its not as tacky! ETC
Jester
See... We can agree..LOL
Doing over head with fiber glass isn't fun... Believe me... And IF you put to many layers at one time,, It will end up on top of your head or lap..LOL..
People can make it stick to metal.. BUT... Like I said,, On a fool.. I'm 240 and if you step on that floor just right... It will pop off the metal... Plus for some reason.. I have seen where people covered rust holes and it rust even more... Maybe the resin does something to the metal...Don't know...
I played with glass a little.. Building this car with no mold...Here's some fenders I hand made as well..made a buck,then made a mold.then made the fenders,,,More on that in my journal..
ID:	71289   Click image for larger version
ID:	71290   Click image for larger version
ID:	71291   Click image for larger version
ID:	71292   Click image for larger version
The Following User Says Thank You to NEW INTERIORS For This Useful Post:
69 widetrack (02-12-2013)
