fiberglass cloth console........
Listen up.as others have posted,forget the cloth,youre not making a surfboard. use only 1 1/2 oz mat,3 layers should be enough,4 layers if youre worried about it,or 10 if you want to support a truck. use a grooved roller(fg supply house) roll the lay up, while it is wet and still soft.as you roll the bubbles out , you will see it get smooth. dont let the glascoats harden,do the rolling when the whole layup is wet. . after you finish up,put an extra coat of poly resin on top .wait til it gets hard. if it gets hard but still sticky,throw it in the swimming pool,or a big bucket of water. that will cut off the air,and allow it to get hard, or just use a hose. really soak it. spray a coat of black spray paint (spray can is ok,) then with a long board sander and probably 80 grit paper,start sanding, the mat buildup,will allow quite a bit of sanding before you break thru.when youve got it pretty smooth,not much black showing THEN use a LITTLE BIT of bondo to make it smooth. then show everyone what a nice job you did
Thats find to use cloth first and cover it with mat, the mat will block the pattern and no problem to use bondo over that. Bondo is just a filler.
John |
| Recent Interior posts with photos |
| fiberglass door panels, dash, center console, sub enclosure, amp rack | liftedbowtie | Interior | 74 | 09-14-2011 11:36 PM |
| Yet another question about bonding fiberglass to metal | Psionic | Body - Exterior | 37 | 01-17-2010 08:03 AM |
| Sanding the *%^$&# primer all off the fiberglass parts | Ripped | Body - Exterior | 7 | 09-01-2007 07:56 PM |
| Making A Fiberglass Console For The First Time | nightrain_rod | Interior | 4 | 03-07-2006 01:46 PM |
| Some quick fiberglass questions... | 94max | Interior | 5 | 06-30-2003 04:21 AM |
