fiberglass console - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2007, 03:00 PM
fiberglass console
I am going to make a small small console about 1ftx1ft. i am going to make it out of fiberboard then lay fiberglass cloth over it. If i put about three layers of glass and sand it smoot do you think that i would need to add any filler or just go ahead and paint it?
Old 09-05-2007, 03:14 PM
SCOOTCH's Avatar
1977 Chevy Impala
maybe a lil filler.. depends on how smooth u can lay the glass and sand it
Old 09-05-2007, 05:20 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Thats the deal..if you can get it smooth enough to satisfy your self..which after a lot of years doing this sort of thing I doubt..should not take a lot of filler though..
Sam
Old 09-05-2007, 06:16 PM
Sam
What kind of filler do you think that i should use. Ive got a gallon of bondo in my garage but ive heard bad things about that. Bondoglass?
What do you recommend
Old 09-05-2007, 08:52 PM
bondo should be fine for a thin skim coat
Shane
Old 09-06-2007, 01:11 AM
Wiki Edits: 3
What is generally done is to use a laminating resin for your layup and then it just takes a thin layer of bondo to make it sandable..So you can use the Bondo you have for the fill..Hope I am clear on this..
Sam
Old 09-06-2007, 08:07 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Check out this link: http://www.fiberglassforums.com/
Good luck.
Old 09-06-2007, 08:34 AM
302 Z28's Avatar
Neat site Dan, but the Auto Interior pics forum is a complete waste of time IMO. Far too many pics of mind numbing stereo installations in rice burners .
Vince
Old 09-06-2007, 09:26 AM
Hi, Don't use cloth the pattern will show through the paint, use mat instead.
John
Old 09-06-2007, 09:37 AM
Wiki Edits: 22
Vince
But Dude, those are so radical and positively tubular!!!! You people who can still hear are so whack!!
Old 09-06-2007, 10:16 AM
302 Z28's Avatar
Vince
Old 09-06-2007, 01:07 PM
John
Im going to be putting a thin layer of bondo over it though
Old 09-06-2007, 01:24 PM
Sam
ok thanks, Ive also heard that the cloth will show through, but if i lay bondo over it you shouldn't be able to see it, right. Would you recommend the cloth, mat, or fleece
Old 09-06-2007, 06:29 PM
Hi, I've done a lot of Corvettes and you never want to put cloth on the outside surface. Even with bondo over it, it will bleed thru, I use mat for any outside surface. I hate to see your hard work change to a finish you don't want.
John
Old 09-06-2007, 07:12 PM
John
what do you think about using the cloth for the first coat then laying mat over that. What about going over that with a filler resin mix instead of the bondo. Or would it be better to just go over it with some rage instead of bondo. Please give me your opinion.
Thank you very much John
Yet another question about bonding fiberglass to metal Psionic Body - Exterior 41 10-20-2013 07:56 PM
fiberglass door panels, dash, center console, sub enclosure, amp rack liftedbowtie Interior 74 09-15-2011 12:36 AM
Sanding the *%^$&# primer all off the fiberglass parts Ripped Body - Exterior 7 09-01-2007 08:56 PM
Making A Fiberglass Console For The First Time nightrain_rod Interior 4 03-07-2006 02:46 PM
Some quick fiberglass questions... 94max Interior 5 06-30-2003 05:21 AM
