Fiberglass Dashboard
Need expertise. I want to fiberglass my dash pad without making a mold. Like most of the late model dash pads the factory foam and pressed vinyl complete the shape. If I strip the dash to plastic it loses its curves. Is there a way to fiberglass or just resin over the pressed vinyl without the results of cracks or possible lifts? I just want to smooth the dash for paint and the pressed vinyl cannot be sanded enough to get that smooth fiberglass look. If I do not make a mold will I be making a mistake? Please help. Thank you
moving to interior forum.
Ontario Rodders |
Glass tutorial
Fiberglass Tutorial
This may help..you may wish to do a layup over the existing dash to smooth it out.. Sam
First test a small area and see if the resin will attack the vinyl and soften it or make it dissolve.
. If it doesn't then I would think that if you glassed over the whole surface of your dash, and secured the edges down somehow, you would ,in essence , be making a foam filled part. I would use 2 layers of 3/4 oz matt and don't sand through it anywhere when you do your smoothing. Hope this helps, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
Thanks Guys. I'll try it out your remedies and let you know what happens.
Gelcoat
hey why do people lay down a whole bunch of wax on a fiberglass dash and then lay GELCOAT? what does the GELCOAT do?
Why not just repair the original dash pad? Check out this site: http://www.justdashes.com/Index.htm or this site: http://www.coverlaymfg.com/index.php?crn=228 or this site on repairing what you have: http://www.performancemetalshaping.n...ge/4811649.htm
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
hey
hey i am making a wood mold right now then im gonna lay a plastic over the top to make a mold. When i lay down the fiberglass cloth do i need to dip it in resin or paint it on? and for a dash how thick of fiberglass should i get? and around how many layers?
If you smooth the wood and wax it good, you don't need plastic it will come off the wood because of the wax. 2 layers of 1 ounce mat should be fine,3 if you want to pound on it when your engine fails. LOL
fiberglass dash
are you sure that its not to thick? if i get the thicker stuff that you are telling me will it bend around all the curves just as good as the thinner stuff and haha hopefully it wont fail
thanks |
You need to tear it so it will lay down in the curves.Don't cut it ,It will show a line.When you tear it it will blend in better.
fiberglass matt
check out this ebay link it says 1 oz per square foot or something check it out and see if its the right stuff for me to buy for the dash??
http://cgi.ebay.com/ebaymotors/FIBER...ayphotohosting Last edited by lgollakner; 12-27-2007 at 11:20 PM. |
| Recent Interior posts with photos |
| Yet another question about bonding fiberglass to metal | Psionic | Body - Exterior | 37 | 01-17-2010 08:03 AM |
| Mounting fiberglass dash | mrmagoo187 | Interior | 24 | 11-04-2005 05:43 PM |
| fiberglass to fiberglass scoop | bluebu | Body - Exterior | 62 | 06-23-2005 05:15 PM |
| Fiberglass dashboard | akattp | Interior | 9 | 11-08-2004 04:47 AM |
| Fiberglass help for novice | tyman00 | Body - Exterior | 1 | 10-20-2004 12:36 AM |
