fiberglass door panels, dash, center console, sub enclosure, amp rack
Was wondering the best way to make fiberglass door panels, dash, center console, sub enclosure, amp rack. Foam and fiberglass mat? wood? PVC Sheets? Or should I use polyester fabric? on door panels I would like to keep stock door handle and stock clips. Would also like to use stock mounting for dash and use stock a/c vents would like to put screen in pass. side. Would like to put scrreen and sub in center console and form that to the floor. The box I want to put under the back seat, plan on lifting seat a little bit, but want to form to the floor. Also would like to form amp rack behind rear seat to the back of the cab. Vehicle is a 1996 chevy k1500 ext cab, I am new to fiberglass but good a bodywork any help would be greatly appreciated.
I AGREE...
... And it is not polite to post in all CAPS. It's hard to read and is like you're YELLING!
On the subject at hand. There was good info there. I'm no expert and all I know is from seeing other people do it but, using fleace as a base to rough shape your panel, and then wet it down with resin. Once that has dried, the final shape can be smoothed using "kitty hair" body filler (filler with fibre glass mixed in) and sanding. A final coat of regular filler will give a perfect surface for painting. |
kristkustoms, I usually don’t post on sites like this; but I couldn’t pass this one up. In your reply (or correction) to traviss10_999 post, in which you complain about his writing prowess you use the wrong inflected form of bad. “Im not trying to be a jerk, but I think that was the worse spelling and grammar that ever went into a post. “
Hi all,
I am new to fiberglass fab and am really interested in giving it a try. I was hoping m1e9r5c6 or anyone could give me an actual product name. I see m1e9r5c6 was talking about "kitty hair" ... who sells it? And what about regular filler (Do you mean regular ol' bondo?) Sorry if these questions are super simple but I am a newbie Thanks, mustang_Tom |
Thanks Jeeptuff for the info.
Now I have a question about the amount of resin needed. I am going to attempt to make a door panel (here in the future) for my 66 mustang, so it will not be any thing complicated. Basically a flat panel with an arm rest molded into it. Anyway back to the question. Anyone have any idea the amout of resin it would take to soak fleece(quart, half gal. or gal.) ? Would one mix this resin say a quart at a time if a gallon is need?
Let's say he's doing this method and want's to mold in a speaker into the door panel.. will this be strong enough to hold the vibrations or will it crack
At the top left of your screen youll see the link for User CP. when you click on that it will take you to your preferences. Then on the left hand side click on Options. Then scroll all the way down, and at the bottom you will see where it change the color from black to white. Brad |
Ah, much, MUCH better! Thanks a lot. (Actually, I'd prefer tan as a "compromise," but the white is certainly better than the black.)
Thanks again. |
fiberglass materials
ive learned ofer the past years through working with fiberglass that fleece is the way to go...i have tried many other materials but nothing compares..the first box i ever built i buit for a girl i knew and it was terrible...i used a bed sheet for a base for the fiberglass and that was a bad idea because it isnt thick enough to withstand the vibrations of a subwoofer and cracked imediatly....but i told her i would finish it for her so i slaped some bondo on it and painted the thing...good friend huh?? well aside from that i started building my skills in fiberglass doing smaller projects such as kick pannels and gauge pods..about two years later i did a full custom interior on my 95 camry but a girl i went to school with hit me and totaled it
...sad yes i know but now i have an 84 chevy pickup that i love and i am in the middle of doin.....my point is i have had many screw ups over the years and i have pretty much got it right now so if you have a question dont be afraid to ask because ive already made all the mistakes..no need for you to make them as well!!
| Recent Interior posts with photos |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
