We're winning the case!
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 03-30-2003, 09:16 AM
markiemyster markiemyster is offline
Post fiberglass drilling
I'm putting a new valance on my vette so I can convert over to standard exhaust instead of side exhaust.
The new valance didn't have any of the holes drilled just a dimple where the holes will go. Also I have to open up the holes for the exhaust tips that are too small.
Can I use a regular drill for the hole and do I need to take any special care so it won't crack the fiberglass and what is the best way of removing about 3/8 of a inch around the opening for the exhaust bezel.
Thanks, Mark
Old 03-30-2003, 10:25 AM
woodz428's Avatar
woodz428 woodz428 is offline
Troll Hunter
Arrow
Whenever I have to drill fiberglass I always put masking tape over it first, if I need to enlarge a hole I use a die grinder with a suitable bit.
Old 03-30-2003, 11:40 AM
4 Jaw Chuck's Avatar
4 Jaw Chuck 4 Jaw Chuck is offline
Post
I would use a large diameter drum sanding roll to enlarge your existing hole, abrasives or a single cut carbide cutter are the best tools for the job with the abrasives giving a smoother cut with less fraying. Masking tape or aluminum tape should be used to prevent chipping.
Outlawed tunes from outlawed pipes
Old 03-30-2003, 03:21 PM
trees's Avatar
trees trees is offline
Post
A quick trip to the local boat shop would be a way of getting some ideals and pointers. They cut holes in 'glass all the time during their rigging process. If you know where and how big, you just might get a freebie.
Trees
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
