Fiberglass fender flares on metal - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2012, 01:04 PM
I have a 1967 mustang. I found fiberglass fender flares that i would like to apply onto it but i don't know the best way to do this Anything is helpful including cure time, glue type, etc. I'm new to this kind of stuff and would appreciate any help or step by step procedure of what to do.
Old 12-16-2012, 01:17 PM
Faith - Respect - Trust
Many manufacturers make adhesives that would work. I use 3M's 8115 body panel adhesive. You would rough up the metal that the flare would be sticking to and the part of the flare that is going onto the wheel wheel with 80 grit. Apply the adhesive and clamp it in place....allow the adhesive to dry for the recommended time and then give it about 6 more hours...remove the clamps and the excess adhesive with 80 grit paper. rough up the outside of the flair and the metal and apply fiberglass filler onto the flare and the metal, making the flare mold into the body. Shape with a block and 80 grit paper. Apply regular filler over top of the fiberglass filler, again, shape with a block and 80 grit, finish with 180 grit and prime.
Ray
The Following User Says Thank You to 69 widetrack For This Useful Post:
big ford7 (12-16-2012)
Hand making Jeep rear metal fender flares ehsankiani Body - Exterior 8 03-13-2006 09:00 AM
Fender flares 66 T-Bird Body - Exterior 6 04-16-2005 10:03 AM
Fender Flares projectis Body - Exterior 8 02-20-2004 02:27 AM
Fender Flares 85ZEE Body - Exterior 6 10-17-2003 06:40 PM
Fender Flares ChrisMiddleron Body - Exterior 1 08-06-2003 12:58 AM
