Fiberglass - Filler - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2009, 03:26 PM
Fiberglass - Filler
I have a fiberglass panel on my vette that has some small pits after sanding off some old resin and primer. I removed some custom body panels that were put on with resin.
Can I just his this with some 2K or should I go over it with filler? The pits are no bigger than the point of a pencil.
Thanks
Steve
Old 04-06-2009, 06:06 PM
MrPhotographer06's Avatar
Army Strong
Last wiki edit: How to remove a VW Type I body
Last journal entry: well once again
Welcome to the site!
If i were you, i'd go over with the filler. its not much of a hassle you'll know that it was done right..
Old 04-06-2009, 06:14 PM
woodz428's Avatar
Troll Hunter
I mix some 'glass resin in with the filler for a smoother finish, that might be a more positive bond. Requires less primer fill that way too.
Old 04-06-2009, 08:39 PM
you can use some glaze putty if its just a few you should be ok, but then use some good primer and block it all smooth
Old 04-06-2009, 08:49 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
I would mix some resin and force into the holes.
Old 04-06-2009, 08:55 PM
resin is almost not needed for small pinholes like it sounds like he has, but if they were larger holes like the size of a penny then yes
Plastic filler tips. MARTINSR Body - Exterior 14 03-03-2009 05:11 PM
The most common mistakes made by the newbe working with plastic filler. MARTINSR Body - Exterior 7 02-14-2006 10:21 PM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
sandpaper... 38 special Body - Exterior 14 10-11-2005 04:30 PM
