Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Interior
  #1
Old 08-04-2006, 04:58 PM
fezz-man fezz-man is offline
New Member
fiberglass firewall fix?
I had to cut open part of the upper indent on the firewall to give room to a distributer on my 51 GMC truck. I do not have the tools or skill yet to weld in a panel with complex curves. I want to fiberglass it in and was wondering 3 things:
1. Will the fiberglass be able to handle the heat of my high horse SBC? The fiberglass will only be directly behind the cap of my distributer.
2. I read about a few guys using chicken wire as a free-form type form. Can this be sandwiched between the layers of fiberglass or does it need to be removed?
3. In the process of building thickness, do you need to sand between cured coats, and will the glass stick well to sanded bare steel?
Thanks
Fezz Man
Old 08-04-2006, 06:31 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
Moderator
re: fiberglass firewall fix?
Do not use chicken wire, it will not hold up well. Check page seven of my photo gallery and see how I did just what you are asking. Of course my body is fiberglass, but the technique is the same. I used 1/8" masonite to build the form and shape I needed. I then laminated several layers of thick resin soaked fiberglass mat on both sides. The best way to do yours is with metal, but since you asked about the fiberglass, yes it will withstand the engine heat just fine.
Vince
Here's to you DoC, you will always be here.
My project 34
http://www.hotrodders.com/forum/34-...ght=34+progress
Old 08-05-2006, 12:59 AM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
oddroddermodderate-tor
 powerrodsmike's barnstar
Wiki Edits: 126
One time I was hard up for a distributer cutout so I took a fire extinguisher, taped off the hollow in the bottom, built a glue flange on it with cardboard and a hot melt glue gun,, waxed it up and used it as a mold.
You really don't want to try to lay up directly on the steel firewall. It won't stick to the steel as good as it could if you made the part and glued it on with panel adhesive or epoxy.
If you want to do a quick and dirty one, rough up the steel, spread a thin coat of bondo. when that cures, sand the bondo until the paper doesn't clog, Then you can lay up over that. The bondo will act like a primer for the resin. You could cut the firewall , then position your form in the hole, then lay up over it.
You can build a form from anything that will hold it's shape, and won't react with the resin. I've used cardboard, pots and cups from the kitchen, carpet roll cores, oxygen cylinders, made them from wood (like vince )
urethane foam. Tape it off and wax it up.
If you use laminating resin, you don't have to sand between coats other than to sand any prickly hairs /lumps down that will mess up your layup. (sanding resin is the one you have to sand)
Hope this helps, mikey
BE different....ACT normal.
Old 08-21-2006, 11:15 PM
New Member
another question...
well, thanks for the advice. I am going to attempt to fill in the gap tomorrow.
Is ther a maximum thickness of matting you want to build to? Can you do it all in 1 shot or do you have to let it cure and build in stages?
Thanks
Fezz
Old 08-21-2006, 11:55 PM
Wiki Edits: 126
Do it all at once if you can. add the minimum amount of catalyst that is required for you temp range, or do it first thing in the morning when it is cool. It will give you more working time.
do 3 or 4 layers of 1 1/2 oz matt, roll it out tight and you will build about 1/8 to 3/16" thickness.
later, mikey
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "fiberglass firewall fix?"
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
Fiberglass Advice Classix_Lover Body - Exterior 9 07-20-2005 11:31 AM
fiberglass to fiberglass scoop bluebu Body - Exterior 62 06-23-2005 05:15 PM
Fiberglass help for novice tyman00 Body - Exterior 1 10-20-2004 12:36 AM
Ballast resistor heat / fiberglass body McDeuce Electrical 1 04-01-2004 02:29 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
