Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Hotrodding Basics
  #1
Old 07-29-2007, 04:14 PM
scratchrod scratchrod is offline
Fiberglass and Heat Tolerance
What is the typical clearance that is required between fiberglass hood / body panels and hot parts such as the engine block, headers, and other exhaust components (to prevent burning or other damage)? Any info is greatly appreciated.
Old 07-29-2007, 08:40 PM
Chevrolet4x4s Chevrolet4x4s is offline
 Chevrolet4x4s's barnstar
re: Fiberglass and Heat Tolerance
good question I'm curious on this one too.
Shane
Old 07-29-2007, 09:01 PM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
oddroddermodderate-tor
 powerrodsmike's barnstar
Wiki Edits: 113
Most resins that are used in the construction of fiberglass automotive parts will tolerate about 180 - 200* F before the resin starts to act weird.
There is no set distance, if you see your hood or whatever getting hot and rubbery and the surface mottling some it's time for a heat shield.
If it's too hot to hold your hand on it for 10 seconds or so then it's too hot, IMO.
Some ISO resins will tolerate 212*, but very few companies that stuff.
Some epoxies will tolerate even more heat...but if it's called fiberglass, chances are that it isn't epoxy.
later, mikey
BE different....ACT normal.
Experience is something you don't get until just after you need it
Old 07-29-2007, 09:46 PM
techinspector1 techinspector1 is online now
Senior Curmudgeon
 techinspector1's barnstar
Wiki Edits: 111
Thanks Mikey, I just learned something.
Old 07-30-2007, 05:03 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
Moderator
I agree with Mikey, if it's close to exhaust it needs a shield between it and the heat source, or consistant air flow.
Vince
Here's to you DoC, you will always be here.
My project 34
http://www.hotrodders.com/forum/34-...ght=34+progress
Old 07-30-2007, 11:18 AM
bentwings's Avatar
bentwings bentwings is offline
bentwings
I'd put some kind of insulation on FG on the inside. Well cured FG is probably good to 200-225 but that is d#m hot to the touch. Search the forum for alternative to lizzard skin. There is a good write up on this. Very good insulation for the cheap.
My Willys is black gel coat and in 15 min in the sun water evaporates very quickly. I've recorded 150+ surface temp. with my little thermo couple temp gage.
Old 07-30-2007, 11:55 AM
shine's Avatar
shine shine is offline
a new body should be sanded put in the sun for a few days to get it cured. then epoxy both sides. excessive heat will " cook out " the resin in a fiberglass panel making it very brittle. epoxy will stop this . on the restomods i use lizard skin s/c and h/c on the bottom and inside the passenger compartment. the exhaust sets right under the tank. this helps keep the fuel cool plus i coat the fuel tank also. for the most part you will see problems in the paint before the resin gives up. hope this helps.
Old 07-30-2007, 01:47 PM
Quarter Flash Quarter Flash is offline
Fiberglass
A company called Coolit makes a sticky back heat shield that might work. Jeg's has it on their site and I assume Summit has it also. I did buy some for my firewall and various lines, hoses and electrical. Have not used it yet but it looks good.
Bob
Old 07-30-2007, 04:35 PM
Wow...thanks for all the great info! I will look into everyone's suggestions and I look forward to any more input!
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Fiberglass and Heat Tolerance"
fiberglass firewall fix? fezz-man Interior 4 08-21-2006 10:55 PM
Excessive heat in the tunnel and floorboards Gregg General Rodding Tech 7 07-18-2005 10:25 PM
More fiberglass questions... Slipangle Body - Exterior 0 04-16-2004 08:36 AM
Fiberglass patch panels? flamedfordbronco Body - Exterior 7 04-10-2004 05:29 PM
Ballast resistor heat / fiberglass body McDeuce Electrical 1 04-01-2004 01:29 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
