Dish washing soap in a bucket of hot water.Wash the area real good with a sponge. Then check with your hand/fingers to see if all the glue is gone.
Rinse with clean water. Then buff it off with some soft rags. this works pretty good or has for me anyway. Or i have been told that "GOO GONE" works well also but i have not tried that yet. but i have use goo gone on alot of painted things with no problems. plastic /metal and glass. JMO Cole Last edited by eloc431962; 05-31-2011 at 03:57 PM. |
Wax and grease remover will take off tape residue. You could just scuff hood with gray scotch brite, wipe it down, tack it and shoot color on it.
Enamel reducer will also safely remove it.
rubbing alcohol ?
sometimes alcohol will work. or carefully heating with a blow dryer type heat gun and wiping with a towel to get most off first. .
My wax and grease remover does not remove tape residue. I picked up some heavy duty degreaser from Lowe's for cleaning the undercarriage, it is called Crud Cutter and is non-toxic and biodegradable. It removes a lot of crap including tape residue and works well for me. I clean the area with wax and grease remover after wiping the Crud Cutter off.
| Looking for fiberglass hood | rollenhard | Body - Exterior | 2 | 01-16-2007 02:25 PM |
| New fiberglass hood problems | 75Malibu | Body - Exterior | 9 | 07-25-2006 02:13 PM |
| fiberglass hood | k-star | Body - Exterior | 4 | 03-29-2006 08:16 AM |
| fiberglass hood bend | MARK TINNELLY | Body - Exterior | 7 | 11-11-2005 09:56 PM |
| fiberglass hood | 77nova64 | Body - Exterior | 2 | 09-07-2003 09:45 PM |
