Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - fiberglass hood
Thread: fiberglass hood
Old 03-29-2006, 08:43 AM
lowROLLERchevy's Avatar
lowROLLERchevy lowROLLERchevy is offline
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
the only way to even try to make a pin on hood into a bolt on unit would be to seperate the inner and outer panels , and then install large steel reinforcment plates before bonding everything back together
the only way around sererating the 2 panels would be to cut access holes in the outside and slide the plates in, but this causes an obvious repair problem
i wouldnt advise doing it either way
