fiberglass hood - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2006, 09:30 AM
Last journal entry: PICTURE TEST
fiberglass hood
Has anyone ever added the supports needed to convert a pin on hood to a bolt on hood????
Keith
Old 03-27-2006, 09:46 AM
hood
anyone????
Old 03-29-2006, 07:21 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Keith,
I wouldn't do it. The pin ons are made MUCH lighter with less structural integrity. They even recommend pinning the bolt ons as a safety factor. I've been doing some research lately.
BTW,
If the pin on fits an 81 Monte, I might be interested.
Old 03-29-2006, 07:43 AM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
the only way to even try to make a pin on hood into a bolt on unit would be to seperate the inner and outer panels , and then install large steel reinforcment plates before bonding everything back together
the only way around sererating the 2 panels would be to cut access holes in the outside and slide the plates in, but this causes an obvious repair problem
i wouldnt advise doing it either way
Old 03-29-2006, 08:16 AM
powerrodsmike's Avatar
Wiki Edits: 161
I don't know if this will work for you, you have to see if you have the room in your inner panel. (skip to the last section if you have no inner panel) I have cut holes in the back of the hood inner panel, then shoved a 3/4" square steel tubing about 3'-4' long, (or as long as you can work with) with a 1/4 X 1X 12" plate welded on it for the hinge to bolt on to. I cut away some of the tube to keep the height at 3/4" with the plate welded on. Once the hole is cut, the piece is test fitted until you can get it all the way in. Make sure the steel does not change the shape of the hood. Drill a hole in the inner panel at the front end of the steel so you can put a sheetmetal screw into the steel and pull it up tight to the inner panel. Put a bead of epoxy, panel adhesive, (steel/composite compatable), on the part of the steel that will come in contact with the inner panel. put it in place then screw it tite to the inner panel. when the epoxy cures, drill and tap the hood hinge mounting holes. Don't let the epoxy or the steel come in contact with the underside of the outer panel unless you can stand some transfer of the glue bondline pattern. you can patch up the hole at the back if you want, usually it doesn't show. I did this on a hood a few years back for a customer, but I can't remember what kind of car it was. I remember that the inner panel had alot of room in it. That made it easy.
Does this hood have any kind of inner panel? I guess I should have asked that first. Doh! Let us know if it has no inner panel . I can help with that too. hope this helps, Mikey
BE different....ACT normal.
Last edited by powerrodsmike; 03-29-2006 at 08:50 PM. Reason: It is easier to edit my old posts than write new ones
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 08:14 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 07:29 AM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
