Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fiberglass hood blocking
Old 01-06-2013, 10:07 AM
MARTINSR MARTINSR is online now
Yeah, it really depends on how much you are filling, if those are real low spots you are dead on, I don't mean to use the poly primer as a "filler", that is for the bondo to do. But when you are close, to spread out filler flat enough all over that hood takes a bunch of skills where poly primer would make it very easy, IF you weren't trying to fill much.
