Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fiberglass hood blocking
  #16 (permalink)
Old 01-06-2013, 12:53 PM
tech69 tech69 is offline
put up or shut up
always good to blow it off quickly when you do the grease and wax trick. I usually only do it on a hood or deck when I'm not sure about it and it will only get primed once more. the last time I used it was on a 69 Camaro firewall bodyline. Guys were stumbling to get it done right and when I got on the task it was apparent that the boss only wanted it primed once more. It worked like a charm. Very good for bodylines, but you do gotta dry it THEN blow it off really good. Never had a problem with it messing with the paint but I'm also asking that it not be primed for a day or two.
