Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fiberglass hood blocking
  #20 (permalink)
Old 01-06-2013, 01:22 PM
tech69 tech69 is offline
put up or shut up
Originally Posted by 69 widetrack View Post
Brian...you are so right...why go looking or asking for potential problems...if your only priming once...and you ask for the panel not to be primed for a day or 2 after you use wax and grease remover on a panel, wouldn't it be more productive to spend more time blocking the panel or even priming twice?
Especially filler...it's basically a loose talc sponge that is designed to suck up anything wet (that's why you rarely see primer coming off of filler), 2 part putty does have a finer grind of talc as you mentioned earlier but it will suck up anything wet as well.
Spent the time and don't look for problems...there are enough problems that can bite you without tempting fate.
Ray
now you guys are sounding like Wyo tech kids..."oh my teacher told me blah blah blah." If it didn't work for people it wouldn't be recommended.
