Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fiberglass hood blocking
  #64 (permalink)
Old 01-08-2013, 03:51 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
I should also mention to you that in the recessed areas on the hood (like on both sides of the scoop) and any low areas, give them several coats of primer before priming the whole hood...allow proper flash time between each coat of primer and you should be good to go
Hope this helps.
Ray
