Fiberglass hood work. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-19-2012, 11:25 AM
ogre's Avatar
the 'Duracell Project'
i would think that just filling the void would double the weight of the hood
my experience with fg hoods is that they are only glued together at the edges
i would cut the side walls out of the recess, jack the center section up and use chopped mat to make it whole again.
grind/sand the center section and 3 inches back into the hood so you can do a proper build up with fiberglass.
i'd grind the center section thin and build up the fiberglass back to the original hood thickness.
put a dozen screws thru the underside of the hood to jack the center section up to where you can fg it.
  #17 (permalink)
Old 11-19-2012, 11:49 AM
life is a temporary assignment
Ogre... Your right about the fix.. I'm not sure if this is the hood he has.. Just one I found.. But if it is ..Yes that is the best way to fix it.. And is easier then most will believe.. And if it's done right.. No one would ever know it was fixed..
  #18 (permalink)
Old 11-19-2012, 12:03 PM
Faith - Respect - Trust
Ogre, you are correct, that is the best and proper way to remove the indentation, I was thinking of a shorter, smaller indentation like on the 68 Camaro, my bad. Good call Ogre.
However if the hood that he has is like the one in the picture I'd leave it alone...I think it looks cool.
  #19 (permalink)
Old 11-19-2012, 01:08 PM
Of course another thing to think about is why fill them at all? This hood is very identifiable for the car removing it makes it "just another car" while with it, it's a Javelin!
I would seriously think about leaving it as is. Making something "different" just to be different is seldom a going reason for doing something. Will removing those lines some how improve the looks? That would be a good reason to remove them, it if improves the looks of the car. If it's being done just to be different I would say re-think it.
  #20 (permalink)
Old 11-19-2012, 01:15 PM
Totally agree Brian, I was thinking of a different, smaller indentation when first offered advice, but if that's the same hood the the Original Post has, leave well enough alone. I think it's one of the things AMC got right.
  #21 (permalink)
Old 11-19-2012, 01:45 PM
And I am not even talking about my opinion if it would improve it or not, I haven't stated that opinion, I am talking the builder and owner of the cars opinion, will HE think removing them will improve the looks of the car. The expectations of the owner is all that matters. If he is doing it to just be different, it is usually a mistake.
  #22 (permalink)
Old 01-21-2015, 06:37 PM
Nope, that's the one I got!
  #23 (permalink)
Old 01-21-2015, 06:41 PM
Well if you think about it, they only had them for 67-69, then when 70' came around it was a different design I believe. Yes it's what makes a Javelin a Javelin, but the reason why I wanted to change it was to add a functional hood scoop, and with the recesses that way to many things going on, on the hood, I think...
  #24 (permalink)
Old 01-22-2015, 10:21 AM
ogre's Avatar
and we've been waiting patiently for 2+ years for your reply
The Following User Says Thank You to ogre For This Useful Post:
MARTINSR (01-22-2015)
  #25 (permalink)
Old 01-22-2015, 11:24 AM
LOLOLOL
  #26 (permalink)
Old 01-22-2015, 12:54 PM
LOL
Well alot has happened it the past couple of years. Other than life, I bought a house, got married, and have a beautiful 14 month old daughter. So the car was'nt totally a priority. But nowwwwwwwwww, I'm kinda revisting with it, hehe.....
used fiberglass hood blade12376 Body - Exterior 1 07-27-2011 08:36 PM
Replacing a metal hood with a fiberglass hood dasyhard Body - Exterior 9 07-12-2011 10:18 PM
fiberglass hood gw1626 Body - Exterior 8 06-01-2011 09:10 PM
fiberglass fenders & hood - who has them, what brand, how much finish work? Chuck78 Body - Exterior 10 09-12-2006 03:36 PM
fiberglass hood 77nova64 Body - Exterior 2 09-07-2003 09:45 PM
