Fiberglass release agent for bolt threads. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2011, 05:08 PM
cboy's Avatar
Last journal entry: Finished
I want to experiment with some "alternative" gear shift knobs. I intend to fill hollow objects with resin and insert a bolt to match the threads on the shift lever before the resin sets up. Hopefully I can then simply remove the dummy bolt after the resin hardens and the knob will thread right onto the shift lever.
But I'm wondering what to use for a "shadetree" release agent. I'm thinking WD40, PAM cooking spray, or Vaseline. I'm concerned that tin foil or other "wraps" will create too many imperfections and the threads won't turn out smooth enough. Also paste wax might be too difficult to completely get into the threads.
Always learning...and sharing what I've learned.
Old 04-29-2011, 05:26 PM
Thier are threaded inserts available,[threaded inside,knurled outside] I believe that's the way I'd go. Ithink you'll have a devil of a time getting any sort of " release agent" on consistantly enough to get good threads. also you could put a rod the desired dia. in your mold, then remove and tap. Just a thought.
dave
Old 04-29-2011, 05:49 PM
ogre's Avatar
the 'Duracell Project'
try a t-nut made for wood, i'd use paste wax to make sure you could turn it out. use a stiff brush to apply it and to remove excess
Old 04-29-2011, 05:58 PM
poncho62's Avatar
Wiki Edits: 5
I think the insert would be the best route....or just drill and tap a hole after
Old 04-29-2011, 09:53 PM
I agree with the threaded insert idea.
Or you might try wrapping the bolt
threads using Saran Wrap or teflon tape.
Old 04-29-2011, 10:10 PM
life is a temporary assignment
I really don't think it will work... The resin by it self isn't very strong... If you try to drill and tap it.. It would most likely crack... If you try glassing around the bolt,, The min you try backing it out,, The little threads will crack.... Something big might stay together,, But glass as small as a thread... I really don't see it not cracking... The insert would be the way I would go...I see that working for sure... Good luck cboy.. I know you will come up with something very cool... I would make a custom one in a lathe... Out of alum.. With some brass inserts pressed in it... You can get very creative on a lathe..
Old 04-30-2011, 12:41 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
maybe a cheaper way to do it, would be just screw a nut onto a bolt and use the nut for the threaded insert.
if this is just a low budget, fooling around, project.
Old 04-30-2011, 04:37 PM
cboy's Avatar
Thanks to everyone for the tips and advice. I'll have to do some experimenting.
Old 04-30-2011, 06:01 PM
31Vicky's Avatar
Just use paste floor wax. Will work fine.
Old 05-04-2011, 05:16 PM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
+ paste wax!
Old 05-15-2011, 10:03 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Try lip balm such as Blistex
Old 05-15-2011, 05:21 PM
S10 Racer's Avatar
Or good ole anti-seize
Old 05-15-2011, 06:42 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
Glass a nut in the knob
Questions about bottom tapping main bolt threads? DEMONSPEED Hotrodding Basics 6 01-07-2011 11:07 AM
Release agent for fiberglass. Thumpin455 Body - Exterior 6 08-19-2009 07:47 AM
flattening agent jerw55 Body - Exterior 0 06-21-2008 09:42 PM
Agent jaybird8 Introduce Yourself 1 05-16-2006 05:17 PM
stripped starter bolt threads 72chevelleguy Engine 2 12-11-2003 09:02 PM
