Fiberglass "rolled edge" - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2012, 01:16 PM
hey,
I am thinking about making some fiberglass fenders. I will use my old fenders to create a mold. I want to create a rolled edge on the wheel well. I can't seem to find anything online about doing this.
Is there a way to do it in the mold or should I pop the fender out of the mold then use clay or a wood frame to make the rolled edge?
Just curious what the "pros" are doing.
Thanks
Jeremy
Old 01-24-2012, 02:55 PM
I think your mold edge needs to come over the inner fender edge, you may need a parting flange, then usually the molded part is just layed up real thick like 3/16- 1/4
The Following User Says Thank You to John Se For This Useful Post:
Carroll (09-13-2012)
Old 01-24-2012, 04:08 PM
Ah of course! I had to google parting flange...
Just to see if i have it right, so make the mold in 2+ parts. Use a clay or something along the parting lines while fiberglassing. Then when it is cured pop the mold apart at the parting flange and release my fender?
Old 01-24-2012, 05:00 PM
check out you tube, there are many videos on making molds and molding fiberglass. Its fun, creative and itchy!
Old 01-24-2012, 07:15 PM
Almost anything will work, think out of the box. you only need to support the fiberglass until it hardens, and then you can remove the support or core.
Paper towel cardboard tubes. If diameter is too large, cut lengthwise, roll into itself, and tape together. Cover with Saran wrap to prevent sticking. Notch one side to form the straight tube into a curved tube.
Tap plastics sells a two part expanding foam, you could pour on the part. After it hardens, easy to shape, and dig the foam out of the cavity. You could also use spray can building insulation.
Carve up a piece of Styrofoam. You must prevent contact with polyester resin, if you use Styrofoam, the resin dissolves Styrofoam. If you use Styrofoam, another option is to use epoxy resin to saturate the fiberglass.
If the part is supported in the right orientation, you might be able to just let the first layer of glass to hang free, and then when it sets, put more layers on. I did a repair of a fan shroud that the fan had a hole from when a motor mount broke just by spanning the hole with a layer of glass soaked with resin.
Potential cure for "gummy" fiberglass resin. cboy Body - Exterior 22 01-09-2016 07:46 PM
Paint repair of roughly 3"x3" on a fiberglass bumper killerformula Body - Exterior 2 01-11-2008 05:12 PM
Seeking "Dave Korrell" fiberglass address Trent Sanders Body - Exterior 0 08-05-2005 01:14 PM
Fiberglass as "bodyfiller" ? vorgath Body - Exterior 6 01-08-2005 01:44 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 02:13 PM
