fiberglass toolbox for pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2006, 04:57 AM
Hi all
I am still going through the tons of thread on fiberglassing and was
wondering it was a good idea as a first time project to build a pickup bed toolbox?
there are available toolbox usually made of aluminum, steel or plastic.
I was thinking of buildng a protype using cardboard and layer it with fiberglass.
What kind reinforcement do you think is needed to achieve a good enough strength into the glass?. Will sandwiching a steel screen with glass will help?
thanks for any ideas.
Old 11-04-2006, 08:05 PM
techinspector1's Avatar
Wiki Edits: 326
I think if I were going to do this, I'd weld up a 3/4" angle iron frame and drill it full of holes so the resin would have some bite.
Old 11-06-2006, 01:05 AM
thanks for the reply.
I have gotten similar responses from other fiberglass guys.
I am currently reconsidering a new approach into learning about fiberglassing technuiques.
Old 11-06-2006, 01:43 AM
you can use mdf for a frame and then fiberglass over
Yet another question about bonding fiberglass to metal Psionic Body - Exterior 41 10-20-2013 06:56 PM
Gap problems fender to door when front fascia installed Ripped Body - Exterior 25 03-19-2006 07:15 PM
Fiberglass Advice Classix_Lover Body - Exterior 9 07-20-2005 11:31 AM
fiberglass to fiberglass scoop bluebu Body - Exterior 62 06-23-2005 05:15 PM
Fiberglass help for novice tyman00 Body - Exterior 1 10-20-2004 12:36 AM
