We're winning the case!
Hotrodders Bulletin Board > Tech Help > Interior
  #31
Old 03-14-2005, 06:40 PM
shearcyr shearcyr is offline
Those who wander are not lost
hey shawn, this is a great post, you should do many more like this for I am sure it will inspire others as it has me... I just started making an instrument cluster to sit on the dash of an 88 chevy pickup after I read your fiberglass tutorial post. it was a little hard for me to get all the shapes I was going for but that is the great thing I have found about fiberglass, you are only limited to your imagination...and TIME! I would love to post a couple pics of it but cannot figure out how
Old 03-15-2005, 09:36 AM
cboy's Avatar
cboy cboy is offline
cboy's barnstar
Wiki editor
Originally Posted by willys36@aol.com
Cboy, That method is great for adding bulk when strength is not important. However, no cloth can stand up to stress very well - that's why 'glas, aramid or carbon fiber come into play. Your body will tell you if it is seeing any stress in pretty short order!!
Good point regarding "stress" as well as "strength". The rat will serve as a good "testing ground" for this little experiment. With not that much money involved, we'll see once it gets on the road how well the cloth alternative holds up. If it starts showing hairline cracks...just get out the grinder and have at it.
Dewey
Old 03-15-2005, 09:55 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
willys36@aol.com's barnstar
Wiki editor
Last wiki edit: Fiberglassing
Wiki Edits: 20
Little known, less cared about fact; Was watching Penn & Teller's new ShowTime show about PC lies and they did an expose' on the rip-off bottled water industry last night. They really showed the stupidity of buying designer water. For example, it says right on the bottle of 'Alaskan Glacier" water that the bottles are filled from the Corpus Christie Texas municipal water system. They mentioned that fleece blanket material is made 100% from recycled polyethylene bottles!
Old 04-16-2005, 09:27 AM
onenew32's Avatar
onenew32 onenew32 is offline
Hot Rodder, and Proud of it
Please do more
Originally Posted by Stinkin_V8
Consider this some decent response! Nice job!
IMO, there aren't rearly enough buildup threads.
This is your response: DO MORE PLEASE !
Old 05-18-2005, 09:43 PM
Charles F. Smith's Avatar
Charles F. Smith Charles F. Smith is offline
KristKustoms
Great article on the dash pod - a friend is building a '32 Coupe with A/C and I'll pass this on to him because he'll probably need it. I know it's a lot of trouble to do these "lessons" and I for one appreciate your efforts.
Charlie Smith
Old 05-19-2005, 06:20 AM
38Chevy3WCoupe 38Chevy3WCoupe is offline
For those who haven't seen it yet --- there's a great article featuring Krist Kustoms in this month's (May '05) Street Scene magazine (NSRA publication). I know I took away a couple of ideas for the console and headliner on my rod. Great work, Shawn, and thanks.
Old 05-19-2005, 07:31 AM
Wiki editor
Wiki Edits: 20
I think Shawn is too good for us now. Hasn't posted since early March.
Old 05-19-2005, 08:32 AM
WakBordr7387's Avatar
WakBordr7387 WakBordr7387 is offline
Gone fishin'
WakBordr7387's barnstar
Wiki editor
Last wiki edit: Removing stuck fasteners
Wiki Edits: 2
Guess thats what happens when you hit the big time.
Brad
Old 07-04-2005, 08:08 PM
Dusty82's Avatar
Dusty82 Dusty82 is offline
If I may, I'd like to add that 1/8th inch thick Lauan plywood is not only cheap, it's easy to find. Most home centers sell 8' X 4' sheets of the stuff, but if you can't find them, ask for an interior hollow-core door skin. They're 7' X 3' and run about $10. Interior hollow-core doors have been faced with Lauan since the '50s, so the skins to repair them are pretty easy to find.
This stuff also works great for making paterns & templates. At the cabinet shop, if we needed to make several complex pieces exactly the same, we made a template out of 1/8th inch Lauan, then used double sided tape to attach it to the wood we wanted to cut out. A quick trip through the router table with a straight bit fitted with a guide bearing, to ride against the template, and we had as many pieces cut as we needed - all consistently the exact same shape.
Old 09-22-2005, 10:18 AM
antiquecar's Avatar
antiquecar antiquecar is offline
old car nut
excellent article. I used the information to make a buck for forming a patch panel. Smoother then glass mat or cloth. Thanks for your time
Jan
Old 11-13-2005, 08:48 AM
kristkustoms's Avatar
kristkustoms kristkustoms is offline
First name...............Shawn
Hey man, ive been busy! Ive been puttin in some work today on here though, trying to answer some questions.
Old 11-26-2005, 09:12 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Jon's barnstar
Wiki editor
Wiki Edits: 6,687
Lightbulb Added to Hotrodders Knowledge Base
This discussion has been added to the Body - Exterior Discussions category of the Hotrodders Knowledge Base.
--For the main page of the Hotrodders Knowledge Base, click here.
--For more information on the Hotrodders Knowledge Base, click here.
--For information on becoming a Hotrodders Knowledge Base Editor, click here.
Old 05-18-2006, 03:54 AM
Scoundrel Scoundrel is offline
Wow
Hey good to be here
Old 05-18-2006, 04:00 AM
I cant believe how much info ive learned from just reading for about 10 minutes! thanks. Also I think KK was saying that you should buy heavy fleece and once soaked it'll be about 3/16 not when you buy it. I had a question that may sound dumb but w/e, im new to this forum and just had to register. Im a skilled woodworker and spend M-F building custom cabinets. I just bought a little 90' vw corrado and really want to turn it into a project car but i dont know the first thing about the first thing. So basically im here to learn. I saw the finsh picture of KK's pods and they look great but when you say upholstry what exactly do you mean? (Cloth?) because the white doesnt look like cloth. What my real question should be is how would i make anything that I make such as gauge pods look like a shiney piece of fiberglass? Like what would you finish it with? I see cool stuff in mags like fully fiberglass interiors color corrdinated or 2-toned, is this most likely airbrushed?.........sorry alot of questions, im a newbie!
Old 06-14-2006, 02:25 PM
aandben aandben is offline
I need more
Great stuff! Please do more tutorials like that one. I have a 51 chevy 2 door sport coupe that I am building. I haven't gotten to the interior work yet but I know that your posts will help a lot! Pics of a door panel build would be great. Thanks for the knowledge!
Back to top
This discussion has been added to the Interior Discussions category of the Hotrodders Knowledge Base.
Search this Thread:
Advanced Search
vB code is On
Forum Jump
