Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fiberglass Tutorial
  #56 (permalink)
Old 10-22-2006, 09:10 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Regardless if you mess up the mix, placing the part in direct sunlight will set the resin every time. The stuff is very UV sensitive so a sticky, gooey part will harden right up in sun.
