Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fiberlass '33 Ford gas tank apron
Old 05-01-2013, 10:05 PM
TucsonJay's Avatar
TucsonJay TucsonJay is offline
I use bolts from Ace Harware called "elevator bolts". They have a thin round head. I grind both sides of the head off leaving a strip with the stud sticking out. That way they will not spin inside the 'glass.
I use 2-3 layers of 'glass matt with a hole poked in them for the stud to stick out of, then just use resin to glue them on.
The Following 2 Users Say Thank You to TucsonJay For This Useful Post:
Ozarkmark (05-02-2013), sedanbob (05-01-2013)
