Fibre Glass Bodies - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2011, 05:44 AM
Fibre Glass Bodies
I have got a quick question about the preparation of a fibre glass body. In my body I have a few seam lines from when the body came out of the mould. I have sanded the body down lightly but found that some of the seam lines need a coat of filler to get them right. Can I fill over the gel coat or does the whole body need a coat of primer and then apply the filler over the primer?
Cheers
Russ
Old 04-23-2011, 07:40 AM
delawarebill's Avatar
glass bodies
either way will work.. i'd do the gel coat.. just make sure u sand the area good for a good tooth..
Old 04-23-2011, 07:44 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would use 80 grit to get some tooth and then filler to suit..then of course get on with the blocking..You have set this out in the sun for a week or two to allow the body to outgas before painting have you not..??
Sam
Old 04-23-2011, 09:04 AM
TucsonJay's Avatar
I agree about putting it in the sun for a week or more. Production 'glass parts often are not fully cured. This will cause them to shrink and move as they do reach a cure. The time in the sun will fix this.
That way, the body is stable, and what ever work you do will be permanent.
Old 04-23-2011, 09:59 AM
dinger's Avatar
Should the body be braced for any type of warpage? Just for my information as well.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 04-23-2011, 10:16 AM
TucsonJay's Avatar
I don't know if you mean during the curing stage, or as it's installed.
Just be aware that fiberglass always will remain somewhat "fluid". If you put pressure on it... like leaning a heavy object against it... over time it can cause a change in shape.
I hope that helps with your question.
Old 04-23-2011, 11:33 AM
35terraplane's Avatar
Fiberglass bodies
Dan if you are asking say should you support the trunk lid if it is open, yes on both sides even when it is done, if you only support on side it will sag from the suns heat, as far as just the body goes, you shouldn't have to. as far as the fenders go the back ones can be laid on there side, the front ones, i'm not sure which way to go, if they are on the car I would support them, off the car upside down, but not sure.
Bob
Old 04-23-2011, 06:12 PM
Thanks for that boys, I have been using 80 grit to get a good key. I have had the body for over a year whilst I got the chassis up and rolling so I hope it should be fully cured by now.
Old 04-23-2011, 06:16 PM
if it hasn't been in the sun.....or out in the uv rays atleast......chances are it still isn't fully cured. "hope" isn't something you wanna be saying after all the paint and body is done. it would still let it sit out for atleast a week.
Old 04-23-2011, 09:35 PM
302 Z28's Avatar
If you have the car assembled, fender and running boards prior to body work for fitment then put it in the sun for as long as possible. This will not only allow the glass to off gas, but will cure the various pieces in the positions they will be installed. Keep in mind that even after the pieces have been painted they will not fit properly. You may have to gingerly force them into final position over several days. Remember heat (sun) is your friend when fitting everything back together. Rough sand everything with 80 grit prior to placing in the sun.
Vince
Fixing Captive Nuts to Fibre Glass ant_8u Body - Exterior 9 02-24-2011 06:10 PM
Any fiber glass channeled bodies? dirtyrats079 General Rodding Tech 2 11-13-2009 01:01 PM
glass bodies bodyman65 Hotrodding Basics 21 09-10-2007 09:02 AM
Glass Bodies Jim Reinhart Introduce Yourself 0 08-05-2004 06:50 AM
'Glass rod bodies Halloweenking Hotrodders' Lounge 6 01-21-2003 03:46 PM
