Fibreglass Hoods - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2004, 12:06 PM
53fordguy's Avatar
Junkyard Kustoms
Last journal entry: update after a long time
Fibreglass Hoods
For my project, I would like to use a clear fiberglass or plexiglass hood. Has anyone heard or know of a place that fabricates them? I would like one for my 53 mercury pick up.
53 fords rule!
Old 10-17-2004, 01:22 PM
Tazz
Fiberglass isn't clear to begin with and the hood for a merc PU truck would be a very special one if someone can make it up for you meaning $$$$$ at least dude!! Buy the stock ford hood and let that do ya!! Just my 2cents for all its worth to ya!!
Tazz
Rat Rods Rule!
Old 10-17-2004, 04:01 PM
53fordguy's Avatar
Junkyard Kustoms
yeah
I just thought it would be really cool.
53 fords rule!
Old 10-19-2004, 08:34 AM
Im trying to have an idea!
Re: yeah
you could make one out of the plexy glass
Old 10-19-2004, 10:58 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Gene Winfield did his own plexi fab for a few rods he built. He mentioned that if you were to take your form (your old hood)and lay the plexi over the top, place it in an oven where it could soften the plexi. The oven could be as simplee as a box with a few 500w quartz lights to provide the heat source.
Question,
How do you intend to support the plexi. Even with shape, its pretty flexible. It'll grind your paint away wherever the edge touchs. Holding it down with hood pins?
Fiberglass may be your better solution, but you'd better think how to reinforce it. Otherwise, it may end in your windshield when you hit 60 mph.
Old 10-19-2004, 12:06 PM
dbuff's Avatar
What if you took a fiberglass hood and inserted plexiglass panels?
Old 10-19-2004, 02:52 PM
leroy lucas's Avatar
New Member
If the hood is clear anyway then just take the hood off just kidding. Your talking big bucks sorry I cant help.
Old 10-19-2004, 08:36 PM
53fordguy's Avatar
Junkyard Kustoms
yeah
I just havent even been able to find any hoods not even on old truck websites, so i was thinking of making one some how, since my hood was used behind a snowmobile its toast and mia. even if i wanted to fix it
53 fords rule!
Old 10-19-2004, 09:07 PM
gemini86's Avatar
Hey, mine's paid for, Punk.
I like the idea of the windows in the hood.
Old 10-19-2004, 11:02 PM
vorgath's Avatar
metal and plexiglass
Think of eyeglasses ... same thing here
Make an outer frame .. "edge" .. of metal.. like a border ... and mount it around the plexiglass... that way it won't flex
Old 10-20-2004, 08:32 AM
Have you been searching for a "Mercury" hood or a "Ford" hood? In the US there was no "Mercury" pickups, that exact same truck was marketed as a "Ford F100" here, there are ZILLLIONS of them and TENS OF ZILLIONS of parts.
My brother is building one at this very time in fact. The hoods are not hard to get and in fact there are fiberglass ones made. I'll try to get you the info on them.
Old 10-20-2004, 06:01 PM
There a company called Fairlane that makes glass products for those years of ford pickups
Old 10-20-2004, 06:07 PM
53fordguy's Avatar
Junkyard Kustoms
lol
yeah i know murc trucks were canadian but i havent even seen another truck in the bushes like it around here but ill keep looking and id love more info!
53 fords rule!
Old 10-20-2004, 06:29 PM
willys36@aol.com's Avatar
Wiki Edits: 21
It is a lot more involved than just heating the plastic. It must be mounted in a wood frame and uniformly heated in an oven to precisely 350F. Then quickl placed on the form and cacuum formed on place. The form must be very smooth and free of anything that doesn´t like 350F and very well reinforced since a few ounces of vacuum can translate into many hundreds of pounds of force over a big area like a hood. IF you had a good pattern and IF you could find an outfit withan oven and vacuum table big enough, plan on paying around $1000 IF the first try worked, which it wouldn´t. A bib bunch of the $1000 is inthe initial setup charge so subsequent tries woudl be relatively cheaper but plan of doing 5 before getting a keeper @ about $250-$300 per. In summary you would invest a minimum $2000, not counting the cost of makign a good mold.
Old 10-20-2004, 06:33 PM
53fordguy's Avatar
Junkyard Kustoms
yeah
well ill probly keep on looking for a metal hood. if any one knows where i can find one from a friend let me know!!
53 fords rule!
