Fiero Compression test....what should the #'s be? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2004, 12:19 PM
Rubberman2003's Avatar
Im about to do a compression test, i know the numbers should be fairly close, but how high should they be, like 110+ or what? 2.8 L....1986 Fiero Se.
Old 02-01-2004, 12:23 PM
lluciano77's Avatar
I would imagine they should be higher than that. At least 130+.
Old 02-01-2004, 12:37 PM
Rhansen's Avatar
Footbraker
That sounds pretty low - were all the cylinders the same psi? You only want a 10% variance between cylinders.
Old 02-01-2004, 01:45 PM
Bout ready to do it now, had to pull the plugs, the plugs toward the front are a PITA to get with big hands
Ok i just ran the test....after seeing the results you know what i must do lol....
Starting toward the front of the car working across it goes...
55/145/100
Starting at the back (drivers side) of the car working across it goes....
130/125/90
Time for my to look for my LT1 OR 3800 w/turbo or blower.
Old 02-01-2004, 03:08 PM
Rhansen's Avatar
Footbraker
There's a guy with a Buick 3.8L turbo in a Fiero that goes to my local dragstrip. It runs 12's and looks bone stock - impressive sleeper. I'm jealous.
Old 02-02-2004, 12:48 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
yup, its shot. Too bad really, I'll bet you could get that little 2.8 to go pretty fast in a fiero. It would probably be a fun project.
K
Old 02-02-2004, 01:17 PM
Yeah, you can always see 1 or 2 of those things at MIR, air they always seem to pull mid 12's.
