fiero rear suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2007, 10:39 PM
hey does anyone know if front springs out of a cadillac eldoraldo(4.5-4.9) would fit into a fiero in the rear of the car(thats where the engine is)
Old 04-22-2007, 12:14 AM
Chopt 48's Avatar
I think the Eldos you mention do have struts.
It might help if you elaborate on what you are attempting to do.
There should be a beefier spring that will fit your applications though. Possibly in the air conditioned V6 cars Like the Citations. Buick, Olds and Pontiac all had their versions.
Old 04-22-2007, 03:34 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
Because of the rearward weight bias of the Fiero, the rear suspension is deliberately "soft." I would suggest that you approach a stiffer Fiero rear suspension with caution. Certainly, this should not be done without first increasing the roll stiffness at the front.
Old 04-22-2007, 08:32 AM
Chopt 48's Avatar
There are several Fiero forums on the net.
Here is a link to one that may produce the information that you want
http://www.fiero.nl/
I haven't checked it out but a quick look shows that it may be helpful for you.
I went back and looked and it looks like they have a good knowledge base there. Some of the members of that forum are heavily involved in serious engine swaps.
Old 05-04-2007, 08:26 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
Don't have an answer to your question but I know you can buy a coil over kit and put after market springs on the back.
I purchased a kit but you could just buy the sleeves and springs.
Wouldn't a sway bar be a better choice if your looking for a better handling ride? Just make sure you put a bigger one in the front and it should be OK.
What kind of V8 do you have?
Old 05-04-2007, 11:42 PM
Last journal entry: Timepiece - Design in Blue
Yeah, PFF (fiero.nl) is a great place for a Fiero owner. I have been a member there for some years now, and still participate even though I don't currrently have a Fiero - just like the people.
BillyShope gave you great advice. Unless you are compensating for a heavier engine (e.g. V8 engine swap) stiffer springs in back, without tightening the front, might not be the best course of action. The Fiero is already known for snap oversteer and that will increase the probability of swapping ends!
Old 05-08-2007, 07:50 PM
Man Todd you are a thread killer, I knew it wasnt me
Old 05-08-2007, 08:59 PM
Hmmm, I have to have ten characters...
independent rear suspension truckboy Suspension - Brakes - Steering 6 05-25-2006 11:33 AM
Rear suspension swap question. almega Suspension - Brakes - Steering 1 06-05-2005 09:52 AM
odd rear suspension problem william27103 Suspension - Brakes - Steering 1 10-18-2004 03:53 PM
rear suspension upgrade tuske427 Suspension - Brakes - Steering 4 08-07-2004 12:38 PM
rear suspension upgrade tuske427 Suspension - Brakes - Steering 0 08-05-2004 01:46 PM
