Figuring Air Compresssor CFM - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2006, 03:28 PM
I "inherited" an old stand up compressor with no air output ratings on it whatsoever. It is a single stage, maybe 30 gallon tank. Name brand is Gilbarco. The tag on the motor states its rpm and a tag on the pump has the bore and stroke. Is figuring the CFM as simple as bore x stroke x rpm(corrected for pully ratio)? [(pi x r^2) x stroke] x rpm
Jamie
Old 04-10-2006, 04:22 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You may have as much luck just doing an estimate from comparing similar compressors..Gilbarco is a service station equipment supplier and has a lot of stuff under its name made by other vendors..
Sam
Old 04-10-2006, 08:35 PM
It would be simple to just use displacement X pump RPM if the the pump were 100% efficient but that is not the case so anything short of using a flow meter would just be a crap shoot.
Old 04-11-2006, 02:08 PM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
One way to compare is to find one with the same size tank that you know
the cfm of. Then measure the time it takes for that one to pump up to
say 100 psi. then compare to yours.
Maybe if you time yours and post it here, someone with that size tank and
similar pump-up time can tell you their cfm spec, you'll get close to
knowing.
An old worn out compressor can run twice as long as a new one,
so cylinder volume by rpm won't really tell you.
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 10:09 PM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 03:18 PM
65 Mustang on Air 1965-Mustang Suspension - Brakes - Steering 6 12-24-2003 05:51 AM
