Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - figuring dynamic compression acuratly
Old 08-23-2012, 01:24 AM
67-4-fun 67-4-fun is offline
my questin is this, to figure dynamic compression acuratly, would you use duration numbers @ .050 example KB calculator or use the advertise duration numbers? my thoughts are you would want to used the advertise duration numbers and not the 50 numbers because the intake valve is not completly closed at 50 which i would think would make your compression number inacurate... please correct me if im wrong on my thoughts and explain if so..
JP
