figuring out coil springs rate - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2002, 12:23 PM
Post figuring out coil springs rate
Can anyone explain? How you figure out spring rate for coil springs?
Old 10-18-2002, 12:56 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Yes there are two ways to do it. The first is a fairly robust mathematical equation. If you are interested in that, send me your email and I send it to you. The other way is to put a known weight on the spring and measure it's deflection. Helical coil springs are rated in inches of deflection per pound of load imposed. Easier said than done without some specialized equipment.
