I guess you are installing new rings in every cylinder and broke ONE ring.
I have seen people install a little used ring with no problems on a fresh cylinder deglaze/hone job, but I sense that if you purchased a new ring set for one piston and installed that new ring, then you would at least know that you did your best. Flip a coin Shade Tree. |
Second rings scrape oil down as much as they hold compression up, so I think that you should look for other problems too. |
yea but if ring is broke , is it not scrapping oil , it's letting compression by and blowing oil |
file to fit rings for a bbc
on the rings , lot of rebuild shops have extras from breaking rings when they install pistons .
so ask around and maybe someone else has some may on here to . i got some 350's |
filing rings to fit cylinder ?
Is there a rule of thumb for file fitting rings to a cylinder. I what just wondering? thank
I say seek other causes. |
| BBC In a GMC Sierra - will it fit? | 69ChevelleAddict | Engine | 4 | 07-09-2006 08:44 PM |
| file fit rings or std. rings | dboyett38666 | Engine | 21 | 03-20-2006 07:32 PM |
| Will BBC headers fit any BBC heads? | brian12c | Engine | 3 | 12-20-2005 11:38 PM |
| Will a BBC fit into a 60's Jaguar? | riverdale | Engine | 8 | 02-18-2004 01:07 AM |
| File back rings. | HQHolden | Engine | 9 | 10-13-2003 07:35 AM |
