Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - file fit rings or std. rings
Old 03-18-2006, 09:15 PM
dboyett38666's Avatar
dboyett38666 dboyett38666 is offline
Originally Posted by dgcantrellsr
If you've never used file fit , I would advise using the regular rings , If the overbore is pretty much exact the non file fit will work just as good and save you a hellava lot of time and headaches, not to mention the money!
I've used file fit on race motors and then freshened them later with non file fit and the car ran the same ET.
Thanks I'll use the standard end gap,its much easier that way.I had another post about the 400 block I am building.It has 3 thousands more clearance at the bottom of the cylinder hope its all-right
