Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - file fit rings or std. rings
Old 03-19-2006, 06:29 AM
NAIRB's Avatar
NAIRB NAIRB is offline Moderator
Originally Posted by dboyett38666
Thanks I'll use the standard end gap,its much easier that way.I had another post about the 400 block I am building.It has 3 thousands more clearance at the bottom of the cylinder hope its all-right
If your cylinders are questionable in terms of roundess or straightness, I would use hastings piston rings. Do you know what grit they finished your cylinder with?
